ONTAP Hardware
Setup e0M prior to use with NSE with Key Manager
Fambo
Hello,
Looking to setup encryption on 7-Mode 8.2.x using a key manger and I’m having trouble finding the process for configuring e0M. I understand how to go through the key_manager setup and specify the e0M port details, I’m assuming you need to have e0M configured and running before you run key_manager setup. In order for the boot to complete e0M must be up in order to communicate to the key manager to retrieve the key and unlock the drives – this happens before the contents of the RC file are applied.
I see some documentation for setting up e0M during the initial setup but how is it configured post setup?
Thanks in advanced for your help and guidance
1 REPLY 1
Jeff_Yao
there's cmd in systemshell "kenv" which could change the environment variables. but use it with caution, coz it could result in panic.
there's kb 1013827 about that.
