Object Storage
Monitor tenant using Grafana
YehudaLevi1999
Hi All,
I have build several dashboards in order to monitor the SG environment .
now , I need to provide a tenant list with the quota . using the metrics I'm getting the tenant id and not the tenant display name.
How can i convert or display the tenant display name on a grafana dashboard. ?
Thanks
1 ACCEPTED SOLUTION
cgrindst
Harvest solves this by querying the REST endpoint "grid/accounts-cache" and joining that response with metrics that include tenant ids. Perhaps you can use Harvest for your solution? Harvest also ships with several StorageGRID dashboards.
https://github.com/NetApp/harvest
1 REPLY 1
cgrindst
