Simulator Discussions
System ID Mismatch and reboot
Atish1
Hi Team,
After clean configuration of Cluster 1 Node 2, I am getting below mentioned Warning. It will get reboot and reboot in simulator.
Ending netapp_loadnvram - 04:13:41 Boot Menu will be available. WARNING: System ID Mismatch. This usually occurs when replacing a boot device or NVRAM cards! Override system ID? {y/n}
Please assist.
1 ACCEPTED SOLUTION
andymirf
Hi.
Did you boot the node BEFORE you changed the sysid for the second node? This usually occurs when the second node has been booted to a login prompt, rebooted and then the boot parameters changed.
If this is the case, just accept )or rebuild the simulator second node and chnage the boot parameters BEFORE a boot).
4 REPLIES 4
andymirf
Hi.
Atish1
Hi andymirf,
Thanks for the reply!
I'll rebuild the simulator second node and change the boot parameters BEFORE a boot. Once done I'll update here in reply.
GINO_ISRAEL
Did you get it running good ? What was the solution ? Thanks !
Atish1
Hi Andymirf and GINO_ISRAEL,
I have rebuilt everything from scratch. Now everything is running fine.
