Simulator Discussions
nfs4_setfacl could not set netAPP NFS volume.
Wencheng
NETAPP simulator version 9.0/9.5/9.7
Client: SuSE12 SP4 which install nfs4-acl-tools
Scenario:
1. I create a aggrgate and a volume which include CIFS and NFS protocols.
2. I try to use suse to mount it by using  mount.nfs4....it mount well.
After mount well...I  try to set nfs ACL by using nfs4_setfacl....
it show error message, whether parameter that I set mistake or something I forgot ??
Thanks!!
Wencheng
5 REPLIES 5
parisi
Looks like you're doing a recursive v4 ACL.
Did you try without -R?
What is the security style of the volume?
Wencheng
Hi Parisi
      as  screenshot, I try to remove -R to set ACL...it show permission...
and I try to chown command...still show permission deny
sorry , I am not linux expert...
whether I should set user could for NetAPP's NFS volume ? or need other actions? to let could run nfs4 set ACL command well ??
thanks
Wencheng
parisi
"nobody:nobody" means that your NFSv4 ID domain is likely mismatched.
What does /var/log/messages on your client show?
You're likely seeing messages like this:
2020-09-01T11:26:17.072485-04:00 sles15 nfsidmap[5338]: nss_getpwnam: name 'nobody' does not map into domain 'DOMAIN.COM'
NFSv4.x requires the following:
- domain set in idmapd.conf
- same domain set in the NFS server option v4-id-domain in ONTAP
- users and groups that match on both client and ONTAP SVM
For example, this is my client:
# cat /etc/idmapd.conf | grep Domain
Domain = NTAP.LOCAL
This is my SVM:
::> nfs show -vserver DEMO -fields v4-id-domain
vserver v4-id-domain
DEMO NTAP.LOCAL
My client can see a user named prof1 and its group ProfGroup (added locally in /etc/passwd and /etc/group):
# id prof1
uid=1102(prof1) gid=10002(ProfGroup) groups=10002(ProfGroup)
My SVM can also resolve that user (mine is using LDAP, but you can also manually add the user and group in the SVM):
::*> getxxbyyy getpwbyname -node ontap9-tme-8040-01 -vserver DEMO -username prof1
(vserver services name-service getxxbyyy getpwbyname)
pw_name: prof1
pw_passwd:
pw_uid: 1102
pw_gid: 10002
pw_gecos:
pw_dir:
pw_shell:
As a result, my client can see the proper user/group ownership. Also, note that there are other folders with "nobody:nobody" because these do not have valid mappings from client to server.
# ls -la
total 9752732
drwxrwxrwx 16 root root 4096 Aug 28 13:32 .
drwxr-xr-x 1 2087 30 462 May 14 20:33 ..
-rwxrwxrwx 1 nobody nobody 4973780992 Aug 5 12:27 Win2019-1M.iso
-rwxr-xr-x 1 root root 4973780992 Aug 17 16:31 Win2019.iso
d--------- 3 root root 4096 Aug 6 13:05 dir
drwxr-xr-x 2 root root 4096 Jun 22 12:51 flexgroup
drwxr-xr-x 3 root root 4096 Jul 10 2017 ftp
drwxrwxrwx 2 root root 4096 Jul 7 2017 ftpuser
d------r-x 2 nobody nobody 4096 May 18 12:32 git
drwxrwxrwx 3 root root 4096 Aug 12 10:24 mtuser
drwx------ 2 nobody nobody 4096 Oct 10 2019 nfs4
drwxr-xr-x 2 prof1 ProfGroup 4096 Aug 12 15:23 prof1
drwxr-xr-x 2 root root 4096 Jul 21 14:51 root
-rw-r--r-- 1 root root 0 May 21 13:27 rootfile
-rw-r--r-- 1 nobody daemon 0 May 21 13:53 rootfile2
drwxr-xr-x 2 root root 4096 Apr 8 22:36 silly
drwx---r-x 2 nobody nobody 4096 Apr 24 13:42 student1
drwxrwxrwx 2 nobody nobody 4096 Apr 24 13:54 student2
drwxrwxrwx 2 root daemon 4096 Feb 24 2017 test
drwxrwxr-x 2 prof1 ProfGroup 4096 Aug 28 13:32 testprof
However, in my other client, which is pointing to the same LDAP server as my SVM, I can see all the owners/groups properly:
# ls -la /mnt/nas
total 9752736
drwxr-xr-x. 14 root root 4096 Aug 17 16:29 ..
d------r-x 2 git git 4096 May 18 12:32 git
drwx------ 2 nfs4 nfs4 4096 Oct 10 2019 nfs4
drwx---r-x 2 student1 group1 4096 Apr 24 13:42 student1
drwxrwxrwx 2 student2 group1 4096 Apr 24 13:54 student2
-rwxrwxrwx 1 admin group1 4973780992 Aug 5 12:27 Win2019-1M.iso
On the SUSE client, I can set NFSv4 ACLs for the user I can resolve (prof1):
sles15:/mnt # nfs4_setfacl -a U:fdSF:[email protected]:rwaDxtTnNcCy /mnt/prof1
sles15:/mnt # nfs4_getfacl /mnt/prof1
A::EVERYONE@:rwaDxtTnNcy
A::OWNER@:rwaDxtTnNcCy
A:g:GROUP@:rwaDxtTnNcy
And I can set it for users only ONTAP knows about:
sles15:/mnt # nfs4_setfacl -a U:fdSF:[email protected]:rwaDxtTnNcCy /mnt/student1
sles15:/mnt # id student1
id: ‘student1’: no such user
sles15:/mnt # nfs4_getfacl /mnt/student1
A::[email protected]:rwaDxtTnNcCy
A:g:[email protected]:rxtncy
A::EVERYONE@:rxtncy
This community isn't really the right place to get into the details of NFSv4.x, setup, etc if you're unfamiliar. I suggest you have a look at TR-4067:
https://www.netapp.com/us/media/tr-4067.pdf
Wencheng
HI
   thanks your document link...
I check v4-id-domain...Yes...I need modify
I have add LDAP setting on SVM_setting from WebConsole...this v4-id-domain could been modify from web console ??
Wencheng
parisi
it's definitely in the GUI in 9.8:
Probably is in 9.7 as well (in the NFS config section).
Older System Manager likely has this as well.
