Simulator Discussions
simulator license problem
ccahuana
Hello,
I hope, someone can help.
I have installed a two node cdot cluster in ESX.
On the system manager on the "license" GUI  I get following error:
"Data ONTAP API Failed :Loop detected in next() for table compliance_status. Next on "NFS 1-81-0000000000000004082368511" returned "NFS 1-81-0000000000000004082368511". (Error: 13001) "
no licenses are listed at all.
I have the same problem with ontap 8.3.2  and ontap 9.0.
On the Clustershell  I wanted to create a  flex clone.  first I added the simulator flexclone license. But creation of a flexclone does not work because the system dont find any license.
Another info: In the Moment when i created a cluster with the first node,  I  found out, that the "License" Gui on the systemmanager is ok . no Errors.But as soon I joined the second node in the cluster, than I get the error.
Can you help?
Thank you.
1 ACCEPTED SOLUTION
SeanHatfield
Licenses are node locked to the serial number of the controller.  It looks like you are using the license key for serial number 4082368511, so check that it matches the serial number of your node.
demo::> node show -fields serialnumber
node  serialnumber
demo9 4082368-51-1
The cluster base license key has to be installed first, so check that as well.
demo::> license show
  (system license show)
Serial Number: 1-80-000008
Owner: demo
Package           Type     Description           Expiration
Base              license  Cluster Base License  -
If both of those check out, you should be able to add feature keys from either the GUI or the CLI,.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
8 REPLIES 8
ekashpureff
Did you change the serial # of the second node at the LOADER firmware prompt before you  joined it into the cluster ?
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, FastLane US http://www.fastlaneus.com/
(P.S. I appreciate 'kudos' on any helpful posts.)
SeanHatfield
node  serialnumber
demo9 4082368-51-1
Owner: demo
ccahuana
Thank you much.  With your Hints  I found the solution.
ANTONIO_SIMULA
SeanHatfield
Start by running these commands and posting the output:
system license show -instance
system license status show
The first will tell us the serial number(s) of your node(s)
The second will tell us which licenses have been installed.
The third will tell us which features were successfully licensed..
ANTONIO_SIMULA
Hi, follow the detail:
show -fields serialnumber:
node show -fields serialnumber -node CL-TEST-01
node serialnumber
CL-TEST-01 4082368-51-1
CL-TEST::> node show -fields serialnumber -node CL-TEST-02
node serialnumber
CL-TEST-02 4082368-51-1
CL-TEST::>
CL-TEST::> system license show -instance
Package: Base
Owner: CL-TEST
Expiration Date: -
Description: Cluster Base License
Type: license
Legacy: no
Customer ID: none
Serial Number: 1-81-0000000000000004082368511
Package: NFS
Owner: CL-TEST-02
Expiration Date: -
Description: NFS License
Type: license
Legacy: no
Customer ID: none
Package: CIFS
Owner: CL-TEST-02
Expiration Date: -
Description: CIFS License
Type: license
Legacy: no
Customer ID: none
Package: iSCSI
Owner: CL-TEST-02
Expiration Date: -
Description: iSCSI License
Type: license
Legacy: no
Customer ID: none
4 entries were displayed.
CL-TEST::> system license status show
Package Licensed Method Expiration
Base license -
NFS license -
CIFS license -
iSCSI license -
FCP none -
SnapRestore none -
SnapMirror none -
FlexClone none -
SnapVault none -
SnapLock none -
SnapManagerSuite none -
SnapProtectApps none -
V_StorageAttach none -
SnapLock_Enterprise
none -
Insight_Balance none -
OCShift none -
16 entries were displayed.
thanks
Antonio
SeanHatfield
It would appear that both of your nodes have the same serial number. Try building a new pair, but make sure the second node uses a different serial number and system id than the first.
ccahuana
Hi,
I had the problem , because i forgot to configure the point  "configuring serial number and system ID for the second node"  of the pdf "Simulate_ONTAP_9.0_Installation_and_Setup_Guide.pdf
Each Simulate ONTAP node in a cluster must have a unique System ID....
By.
Atilio.
