Software Development Kit (SDK) and API Discussions
How to get NAA for lun or volume
HASMIK_HAYRAPETYAN
Hi,
I am looking for ways to get NAA identifier for NetApp volumes and luns using DFM Server API. Does DFM's API provide such functionality?
Thanks in advance for any help.
1 ACCEPTED SOLUTION
obrakmann
Arguably the easiest way to map from a LUN to the corresponding datastore is to use the VSC. That's manual though, no programming involved.
If you need a program or a script to do the mapping, Rick's answer already was correct:
A LUN's 'naa.' number IS its WWN, it's just another name.
To get the WWN, you use the serial-number of the LUN, convert it to its hexadecimal ASCII representation* and prefix it with "naa.60a98000". You can get the LUN serial-number using the 'lun-list-info' API call (to a filer, not to the DFM).
Hope that clears it up.
* So, a '1' is 0x31, an 'a' is 0x61 etc.
22 REPLIES 22
ALEXANDER_KRIVOSHEIN
Ok, folks, same story, but for c-mode? Smiley Happy
There is no Get-NcLunSerialNumbercommand.
Just to remind you, simple script for 7-mode
$LUNs = Get-NaLun
foreach ($LUN in $LUNs)
    $sn = Get-NaLunSerialNumber $LUN.Path
    $b = $sn.ToCharArray();
    Foreach ($element in $b) {$c = $c + [System.String]::Format("{0:X}", [System.Convert]::ToUInt32($element))}
    $LUNWWN = "naa.60a98000" + $c
    Write-Host $sn $LUNWWN $LUN.Path
mbeattie
Hi,
Sure it's possible to convert the LUN Serial number to its Naa number for clustered data ONTAP using PowerShell. Here is a simple example
Import-Module DataONTAP
$cluster      = "cluster1.netapp.com"
$vserver      = "vserver1"
$lunPath      = "/vol/vol1/luns/lun1"
$identifier   = "naa.600a0980"
$credentials  = $host.ui.PromptForCredential("Connect to cluster $cluster", "Please enter the user name and password","","")
$cluster      = Connect-NcController $cluster -Credential($cred)
$lun          = Get-NcLun -Vserver $vserver -Path $lunPath -Controller $cluster
$serialNumber = $lun.SerialNumber
$ca           = $serialNumber.ToCharArray();
$naasn        = $null
Foreach($byte in $ca){
   $naasn = $naasn + [System.String]::Format("{0:x}", [System.Convert]::ToUInt32($byte))
Write-Host "LunPath,LunSerial,NaaNumber"
Write-Host "$lunPath,$serialNumber,$identifier$naasn"
The output will look like:
/vol/vol1/luns/lun1,BpEwv$ElzqhW,naa.600a0980427045777624456c7a716857
Also note that you can use the "lun serial -x" command in ONTAP 8.3 if you'd prefer to use the CLI. See following KB
https://kb-stage.netapp.com/support/index?id=1012613&page=content&locale=en_US
/matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
