Software Development Kit (SDK) and API Discussions
filestats command using system-cli API
haritha_n
filestats command is available in CLI (an example below):
[root]# rsh myfiler filestats volume myvolume snapshot mysnapshot
VOL=myvolume SNAPSHOT=mysnapshot
INODES=983031 COUNTED_INODES=39845 TOTAL_BYTES=8725924057 TOTAL_KB=8586296
I am trying to run the same command using system-cli API. The API runs fine, no error is reported, but, I can't see any output in "cli-output".
use NaServer;
use NaElement;
use Data::Dumper;
my $filer = "myfiler";
my $volume = "myvolume";
my $snapshot = "mysnapshot";
my $user = "<user>";
my $passwd = "<passwd>";
my $api = NaServer->new( $filer, 1, 4 );
$api->set_style("LOGIN");
$api->set_admin_user($user, $passwd);
$api->set_transport_type(NA_SERVER_TRANSPORT_HTTP);
my $cmd      = new NaElement('system-cli');
my $cmd_args = new NaElement('args');
my @arg_arr  = ('filestats', 'volume', $volume, 'snapshot', $snapshot);
foreach my $arg (@arg_arr)
    $cmd_args->child_add(new NaElement('arg', $arg));
$cmd->child_add($cmd_args);
my $result = $api->invoke_elem($cmd);
print "Result ". Dumper($result) . "\n";
if ($result->results_errno != 0)
  my $reason = $out->results_reason();
  print "Invoke Failed: $reason\n";
my $output = $result->child_get_string("cli-output");
print "Output: " . Dumper($output) . "\n";
When I run this script, I see:
% perl test_filestats.pl
Result $VAR1 = bless( {
                 'content' => '',
                 'name' => 'results',
                 'children' => [
                                 bless( {
                                          'content' => '',
                                          'name' => 'cli-output',
                                          'children' => [],
                                          'attrvals' => [],
                                          'attrkeys' => []
                                        }, 'NaElement' ),
                                 bless( {
                                          'content' => '1',
                                          'name' => 'cli-result-value',
                                          'children' => [],
                                          'attrvals' => [],
                                          'attrkeys' => []
                                        }, 'NaElement' )
                 'attrvals' => [
                                 'passed'
                 'attrkeys' => [
                                 'status'
               }, 'NaElement' );
Output: $VAR1 = '';
So, there is no error, but, no output either. Am I invoking the API in a wrong way? How to get the output of filestats command through system-cli call?
Thanks,
Haritha
3 REPLIES 3
rle
NetApp Alumni
Hi Haritha -
I don't know what version of ONTAP you're running, but this sounds like burt 400086 which was fixed in ONTAP 8.0.2.
Also, a good debugging technique would be to do: print $cmd->sprintf() . "\n"; to verify the element input.
Regards,
   - Rick -
haritha_n
Thanks Rick. I am running  ONTAP 7.3.4P4 version.
Thanks for the "sprintf" tip. It confirmed that the input is correct:
   Debug Command input :
     <system-cli>
        <args>
                <arg>filestats</arg>
                <arg>volume</arg>
                <arg>myvolume</arg>
                <arg>snapshot</arg>
                <arg>mysnapshot</arg>
        </args>
    </system-cli>
If any of you have access to ONTAP 8.0.2 or later versions, can you try running similar command and confirm that it works in 8.0.2+? Based on this information, I will have to recommend upgrade to the required ONTAP version as well as suggest a workaround for earlier versions.
Thanks,
Haritha
chris_algar
I am also seeing this problem for system-cli for ndmpd commands in various 7.3.x releases. Does anyone have a list of which commands are not funcional via system-cli, and if this has been fixed for the general case so that all cli commands for which there is no spcific API call can be issued via system-cli.
I'd like to write a full coverage API for 7-Mode using the HTTPS connector, to do so I need to know what the target release for full coverage should be.
Thanks
