Software Development Kit (SDK) and API Discussions
na_ontap_volume faisl to delete a volume on a filer when using state: absent
i created a new 1GB test volume using the ontap CLI , to test the deletion process. ... like so ....
emdccn0006::> vol create -vserver emdccn0005v55dr -volume testvol_12345 -aggregate emdccn0006c02_aggr2 -size 1g -state online
emdccn0006::>
emdccn0006::> vol show testvol_12345
Vserver Volume Aggregate State Type Size Available Used%
emdccn0005v55dr testvol_12345 emdccn0006c02_aggr2 online RW 1GB 972.6MB 5%
emdccn0006::>
emdccn0006::>
emdccn0006::> version
NetApp Release 9.1P16: Wed Nov 14 19:51:52 UTC 2018
emdccn0006::>
so filer = version 9.1P16
the ansible doco for na_ontap_volume shows the following example ...
- name: Volume Delete na_ontap_volume: state: absent name: ansibleVolume12 aggregate_name: ansible_aggr vserver: ansibleVServer hostname: "{{ netapp_hostname }}" username: "{{ netapp_username }}" password: "{{ netapp_password }}"
so following on from this .....
i then created a yml file to delete the volume using ansible like so ...
$ cat delete-dr-volume.yml
- hosts: localhost
gather_facts: false
name: "Ansible Storage Delete ..."
tasks:
- name: "Delete Volume : testvol_12345 , if it exists ..."
na_ontap_volume:
state: absent
aggregate_name: emdccn0006c02_aggr2
vserver: emdccn0005v55dr
hostname: emdccn0006.dc.corp.abc.com
username: admin
password: XXXXX
(cut and paste didnt quite align , noted above )
d629924@vm010$ pip show netapp-lib
Version: 2019.12.20
Summary: netapp-lib is required for Ansible deployments to interact with NetApp storage systems.
Home-page: UNKNOWN
Author: NetApp, Inc.
Author-email: [email protected]
License: Proprietary::NetApp
Requires: lxml, xmltodict
Required-by:
note : i'm using netapp-lib = Version: 2019.12.20
i get this error when running the playbook ...
$ ansible-playbook ./pb-delete/delete-dr-volume.yml
[WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'
PLAY [Ansible Storage Delete ...] *******************************************************************************************************************
TASK [Delete Volume : testvol_12345 , if it exists ...] ********************************************************************************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: KeyError: 'No element by given name volume-comp-aggr-attributes.'
fatal: [localhost]: FAILED! => {"changed": false, "module_stderr": "Traceback (most recent call last):\n File \"/home/d629924/.ansible/tmp/ansible-tmp-1610682403.28-220492199842676/AnsiballZ_na_ontap_volume.py\", line 102, in <module>\n _ansiballz_main()\n File \"/home/d629924/.ansible/tmp/ansible-tmp-1610682403.28-220492199842676/AnsiballZ_na_ontap_volume.py\", line 94, in _ansiballz_main\n invoke_module(zipped_mod, temp_path, ANSIBALLZ_PARAMS)\n File \"/home/d629924/.ansible/tmp/ansible-tmp-1610682403.28-220492199842676/AnsiballZ_na_ontap_volume.py\", line 40, in invoke_module\n runpy.run_module(mod_name='ansible.modules.storage.netapp.na_ontap_volume', init_globals=None, run_name='__main__', alter_sys=True)\n File \"/usr/lib64/python2.7/runpy.py\", line 176, in run_module\n fname, loader, pkg_name)\n File \"/usr/lib64/python2.7/runpy.py\", line 82, in _run_module_code\n mod_name, mod_fname, mod_loader, pkg_name)\n File \"/usr/lib64/python2.7/runpy.py\", line 72, in _run_code\n exec code in run_globals\n File \"/tmp/ansible_na_ontap_volume_payload_MN3wQK/ansible_na_ontap_volume_payload.zip/ansible/modules/storage/netapp/na_ontap_volume.py\", line 1283, in <module>\n File \"/tmp/ansible_na_ontap_volume_payload_MN3wQK/ansible_na_ontap_volume_payload.zip/ansible/modules/storage/netapp/na_ontap_volume.py\", line 1279, in main\n File \"/tmp/ansible_na_ontap_volume_payload_MN3wQK/ansible_na_ontap_volume_payload.zip/ansible/modules/storage/netapp/na_ontap_volume.py\", line 1221, in apply\n File \"/tmp/ansible_na_ontap_volume_payload_MN3wQK/ansible_na_ontap_volume_payload.zip/ansible/modules/storage/netapp/na_ontap_volume.py\", line 565, in get_volume\n File \"/usr/lib/python2.7/site-packages/netapp_lib/api/zapi/zapi.py\", line 489, in __getitem__\n raise KeyError('No element by given name %s.' % key)\nKeyError: 'No element by given name volume-comp-aggr-attributes.'\n", "module_stdout": "", "msg": "MODULE FAILURE\nSee stdout/stderr for the exact error", "rc": 1}
PLAY RECAP ******************************************************************************************************************************************
localhost : ok=0 changed=0 unreachable=0 failed=1 skipped=0 rescued=0 ignored=0
the specific error is :
Can anyone assist me with my issue ? Not sure what i'm doing wrong, unless the fix is a netapp-lib upgrade ?
Regards Adrian
Solved! See The Solution
Hi Adrian,
The slack channels on https://netapp.io is the quickest place to get help on this.
A few points about what's going on.
1. You might want to consider a ONTAP upgrade to 9.5+
2. I don't think you need to specify the aggregate_name in the remove command
3. You might need to unmount the volume prior to deleting it.
4. ONTAP collections have replaced the syntax your currently using which would also address points 2 and 3 above there is a blog post on netapp.io that addresses this topic.
I hope this helps!
John
Hi Adrian,
I hope this helps!
John
I'm facing the same issue with error "No element by given name volume-comp-aggr-attributes." when running a playbook with na_ontap_volume: onto ONTAP Release 9.1P9
This happens when run the playbook for the 2nd or more time.
Is this due to the lower ONTAP-release?
Hello @maartendeboer ,
Yes, it is due to running ONTAP 9.1P9 as composite aggregate also referred to as FabricPool wasn't introduced until ONTAP 9.2.
Regards,
Team NetApp
Fixed by putting
collections:
- netapp.ontap
in playbook.
As mentioned in https://netapp.io/2019/09/17/coming-together-nicely/
--- - hosts: localhost collections: - netapp.ontap
Don't forget to do the action above this section.
