VMware Solutions Discussions
VMWare and Netapp using FCP recommendations
CHRISLAWLOR
hi all
we have a customer who has bought VMWare (vsphere 5) and a FAS 3240C - they have the FCP license and wish to present LUNS to the 3 ESXi hosts with around 3TB for virtual machines
what would you recommend to do in terms of datastores and LUN presentation ? we were thinking to present 5 x 600GB LUNs to all 3 ESXi hosts, and create a seperate datastore per LUN, each LUN would also be in a seperate volume on the same aggregate
im aware that we would lose the dedupe capability between the datastores with the above
any suggestions would be great
thanks
2 REPLIES 2
radek_kubka
Hi and welcome to the Community!
Datastore size is a subject to a personal preference, but I would probably lean towards fewer & larger datastores (still sticking to the rule one datastore, one LUN per volume).
LUN-wide locking (leading to the idea of having more smaller LUNs) was a bit over-hyped in vSphere 4 & in version 5 this can be safely ignored completely thanks to the introduction of Atomic Test & Set (ATS), http://blogs.vmware.com/vsphere/2011/07/new-vsphere-50-storage-features-part-1-vmfs-5.html
From the NetApp side perspective this is also worth noting - http://media.netapp.com/documents/tr-3749.pdf, p9:
Although spanned datastores can overcome the 2TB LUN size limit, they are most commonly used to overcome scaling limits imposed by storage arrays that use per LUN I/O queues. These traditional architectures place a limit on the number of simultaneous commands that can be sent to a LUN at a given time, which can impede overall I/O performance in a datastore.
Storage arrays powered by Data ONTAP are free of this legacy architecture; therefore, NetApp does not recommend the use of spanned VMFS datastores.
Regards,
Radek
CHRISLAWLOR
Thanks Radek
Chris
