VMware Solutions Discussions
VSC 6.1 Snapvault not updated
MichaelWeber
Hi all,
i use VSC 6.1 with VMware vCenter Appliance 6U1 and Ontap 8.2.
I can create Backups but the snapvault relationship is not upgraded. i mean: i get a snapshot on node A but the existing snapvault relationship is not triggered, so i dont get the Snapshot to Node B.
In vSphere 5.1 and VSC 4.x i sued SV-SMVI Script to get it work. With the new VSC i thought i can do this without any externals scripts?
Can you tell me if i need to setuo SV-SMVI with VSC 6.1?
Or am i missing any settings? (Update Snapvault is set in the Backup Job)
i am not using SnapCenter..
Thanks for any help!
in vSPherin
2 REPLIES 2
Sahana
Hi,
SnapVault is only supported for cDOT datastores in VSC 6.1 (this has been true ever since SnapVault support was first added to VSC 5.0).  The SV-SMVI script supports SnapVault for 7-mode datastores, so I’m thinking that you are not yet using cDOT, which means that SnapVault is not supported. Both SMVI and NextGen BnR (SnapCenter plug-in) work only with cDOT based SnapVault.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
MichaelWeber
Thank You very much. So i will read the smvi documentation and check if there is a Solution for 7-Mode with 8.2
