VMware Solutions Discussions
VSC vSphere iSCSI provisioning management network problem
JONATHAN_PINTO
Hi
I have a problem with VSC plugin for VMware. My environment is:
vSphere 5.1
VSC 4.2.1P1 (on VM Windows 2008 server R2) outside the vmware environment, with visibility only the management network.
DataOnTap 8.2.2RC1 7-Mode
FAS-2552 (with VIF to ESX, to iSCSI provisioning, and management network e0M)
After adding controllers to VSC plugin (for network management).
When trying to create a datastore, since the creation fails on ESX servers, because  ESX server displays iSCSI initiators the management IP address, instead of IP address of iSCSI (VIF) network.
I have tried the following:
- Remove controllers, uninstall and reinstall VSC plugin.
- Install another version of VSC
- Edit the file kaminoprefs:
     default.allow.iscsi.mount.networks: iSCSI network
     default.restrict.iscsi.mount.networks: network administration
No positive results
It only works if I manually add the IP address of the iSCSI (VIF) network to each of the ESX servers.
I hope you can help me.
greetings
0 REPLIES 0
