VMware Solutions Discussions
Virtual Storage Console 2.0.1 and vCenter 4.1?
jasonnash
We currently run the Virtual Storage Console with VMware vCenter 4.0, we are looking to upgrade vCenter to 4.1 but cannot find any documentation to detail compatibility.
The Netapp documentation advises to refer to the Interoperability Matrix but I cannot seem to find any detail in here. Does anyone know if the Virtual Storage Console 2.0.1 is compatible/supported with vCenter 4.1?
Jason
1 ACCEPTED SOLUTION
aborzenkov
According to IMT VSC 2.0.1 is compatible with vCenter 4.1.
3 REPLIES 3
aborzenkov
jasonnash
Thanks for this, I did try to check the IMT tool but I couldn't seem to find the VSC anywhere.
aborzenkov
You need to change Storage Solution (Search Criteria frame on the top) to Virtual Storage Console; default is SAN.
