VMware Solutions Discussions
Virtual Storage Console 4.0 for VMware
UGUR_OEZKAN
Dear All
I have upgraded one of my vCenter the VSC plugin from 2.1 to the version 4.0, Unfortunately I could not make an update  from the version 2.1 to the version 4.0 because I had several errors,
I was ordered to completely uninstall the version 2.1, and reinstall the version 4.0 and had to everything to reconfigure, but my problem now is that the snapshot backups of the version 2.1
does not be seen with the new version 4.0.
Unfortunately, I have now snapshot backups from the previous version 2.1 on my volumes, I want to delete this manually every day now, I do not want to delete everything at once,
I think in case of a restore requests I could copy the. vmdk manually from this snapshots.
can anybody tell me whether these steps are ok or maybe there is another better solution?
I thank in advance for any help
  %/used       %/total  date          name
  5% ( 5%)    3% ( 3%)  Jul 28 03:56  smvi__backup_Consistent_recent
13% ( 9%)    7% ( 5%)  Jul 27 15:01  hourly.0
13% ( 0%)    7% ( 0%)  Jul 27 14:00  smvi_SERVERLABORA01_novmsnap_recent
16% ( 4%)    9% ( 2%)  Jul 27 09:00  hourly.1
17% ( 2%)   10% ( 1%)  Jul 27 02:00  smvi_Not Consistent_novmsnap_recent
17% ( 0%)   10% ( 0%)  Jul 27 01:12  smvi__Consistent_recent
18% ( 2%)   11% ( 1%)  Jul 27 00:00  nightly.0
22% ( 5%)   14% ( 3%)  Jul 26 14:25  SANNORDNA01(1573969455)_ESX_VOL2.1
22% ( 0%)   14% ( 0%)  Jul 26 14:00  smvi_SERVERLABORA01_novmsnap_20120726140000
24% ( 4%)   16% ( 2%)  Jul 26 02:00  smvi_Not Consistent_novmsnap_20120726020001
27% ( 4%)   18% ( 2%)  Jul 26 01:11  smvi__Consistent_20120726010003
29% ( 4%)   20% ( 2%)  Jul 25 14:00  smvi_SERVERLABORA01_novmsnap_20120725140000
31% ( 3%)   22% ( 2%)  Jul 25 02:00  smvi_Not Consistent_novmsnap_20120725020001
31% ( 0%)   22% ( 0%)  Jul 25 01:11  smvi__Consistent_20120725010002
32% ( 2%)   23% ( 1%)  Jul 24 14:00  smvi_SERVERLABORA01_novmsnap_20120724140000
33% ( 2%)   24% ( 1%)  Jul 24 02:00  smvi_Not Consistent_novmsnap_20120724020001
34% ( 3%)   25% ( 1%)  Jul 24 01:11  smvi__Consistent_20120724010003
36% ( 5%)   28% ( 3%)  Jul 23 14:00  smvi_SERVERLABORA01_novmsnap_20120723140001
37% ( 2%)   29% ( 1%)  Jul 23 02:00  smvi_Not Consistent_novmsnap_20120723020001
38% ( 3%)   30% ( 2%)  Jul 23 01:16  smvi__Consistent_20120723010003
3 REPLIES 3
mharding
Hello - I noticed you never got a response.  You should try the same post on our Virtualization community page: https://communities.netapp.com/community/products_and_solutions/virtualization
GUILHERME_BUZIOLI
Hi Ugur.
I hade the same problem, and I solve it deleting the snapshot performed by VSC 2.0..
baranowskij
That should work and you can test if you have access to the volume share or admin share.
I use vfilers which automatically create the admin shares \\vfiler\c$\vol\volname\~snapshot. If you do not use vfilers, you would need to create a share to the volume (would recommend hidden share and/or share permissions).
\\netapp\sharename\~snapshot
Also, instead of recovering the entire VMDK, you may want to look at NetApp VMDK mounter where you can browse the snapshot right click on the vmdk and mount to your workstation/server and recover an individual file/database. https://communities.netapp.com/community/netapp-blogs/storage_nuts_n_bolts/blog/2008/07/23/file-level-recovery-from-within-a-vmdk-backup
This vmdk mounter works on x64 by copying the directory created during install to one of the following directories and making sure it is in both "Program files" & "Program files (x86)".
The above would be through windows/cifs
Through the Virtual Center client
You could also browse datatstore snapshots with the VIC and copy the VMDKs to other VMs and attach the copied VMDK to a different VM. This however take longer and has more steps/
