Ask The Experts
Netapp Data Broker web interface connection issue
luc_beaudoinlefort
I'm trying to connect to the web interface of my new install of Netapp DAta Broker with SnapCenter 4.2
everything is pingnig well
but I have the message "This site can’t be reached" when I put
https://data broker appliance IP:8080
any ideas ?
4 REPLIES 4
Ontapforrum
Could you ensure this:
1) Firewall is disabled (or Ports are allowed)
2) Both Data broker IP & Hostname resolution works from SnapCenter server.
luc_beaudoinlefort
Firewall is disabled ...
I can ping the snapcenter server ... and the NEtapp data broker appliance
I installed and configured the appliance, when I use the link that the appliance tells me to use, I got the message
if I go in Maintenance console, I have Appliance services status : not running
I can't start the service ...
any idea
Ontapforrum
I don't have access to databroker, so I can't really do much but I have few suggestions:
[On Page 26]
https://library.netapp.com/ecm/ecm_get_file/ECMLP2858035
Could you try these steps from the ,maintenance console:
1) Display NetApp Data Broker summary
2) Start or stop NetApp Data Broker service
3) Ping a host [SnapCenter]
4) Reboot
If that dosen't work, go for diags:
Support and Diagnostics:
a) Generate support bundle
b) Access diagnostic shell
c) Enable remote diagnostic access
d) Generate core dump bundle
So that anyone in the forum can take a look and guide you further.
bhenson
Same issue here. From talks with my SE buddies, this is an issue, but there aren't too many customers migrated to SC 4.2 and Data Broker, so... maybe there will be a fix (4.2.1 or 1.1)?
For t-shoot, I've gone through all the steps - disabled firewall in SC's Windows Server, checked services, checked DNS resolution, restarted Data Broker, just about everything short of a clean install. There's definitely a bug affecting some users. Let us know if you ever get it sorted out.
