ONTAP Discussions
FAS2020 to FAS2520 migration without client changes
GerarCR
Hi everyone:
We are going to perform a migration from FAS2020 to FAS2520 (both dual controller). We would want to perform this without changes in the clients (nfs and cifs mappings, vmware datastores, iscsi connections... etc).
This is what we have to migrate from the FAS2020:
-Filer1: - one volume wich contains 1 VMWARE datastore accesed vía NFS and contains all the virtual machines.
-Filer2: - 3 volumes containing CIFS shares for user files.
            - 1 volume containing 1 LUN accesed vía iSCSI for a backup software
Our plan is to do the follwing steps:
-Ask for 4 snapmirror test licenses (one for each controller).
-Set up the new FAS2520 with temporal hostnames and IPs
-Set up a snapmirror relationship to migrate all volumes.
-Stop client access to the old filer and perform an snamirror update. (stop VMWARE virtual machines and backup software, and stop cifs in the filer)
-Break and release snapmirror relationships
-Set up iscsi, cifs and nfs options to match the old ones (iscsi groups, lun mappings,cifs shares and nfs exports).
-Change hostnames and Ips in the old filers (so there is no duplicated ones when we rename the new filers)
-Change hostnames and IPs in the new filers to match the ones mapped in the clients.
-Restart client access
Do you think this is the right procedure? Anyone has any advice about this?
Is it possible to move the location path for the entire Datastore in the Vcenter (with all the virtual machines turnet off)?
I have no experience with iSCSI, will this procedure work for this?
Best Regards,
Gerardo
1 ACCEPTED SOLUTION
A_Tomczak
Hello Gerardo,
Iscsi: Don´t forget to change the IQN on the destination Filer and change the serial number of the destination LUN to the old one.
Cifs: Restart the Cifs setup process after hostname change.
NFS: If the ip address and or hostname plus the exports are the same the datastore should come online afer a ESX server reboot.
Everything you want to have is possible but you have to go in more detail.
Alex
7 REPLIES 7
A_Tomczak
Hello Gerardo,
Alex
satechelp
Hi Alex
Thanks for the response I have been checking for more info and the procedure (taking care of the things you have pointed) seem to be fine.
I´ll let you know the results when its done.
Gerardo
SAMIH
HI
Can you please provide me the procedure that you are follow in your migration, because I want to migrate volume, luns, shares and exports from FAS3020 to FAS3220.
For vmware Luns I used storage vmotion.
But for linux luns, CIFS and NFS i used snapmirror, but until now I cant access to new lun from linux hosts.
Br
SAMIH Azzeddine
GerarCR
In the new Filer:
-Created initiator groups as they were in the old filer
-Changed the target nodename to the old filer one
-Changed all the serial luns to the older ones
Restarted clients (without any configuration change on them) and everything worked perfect.
SAMIH
Hi
Thank you very much for your feedback.
Today I am trying the follwing in the testbed server:
  1. I Initialize snapmirror to other controller.
  2. I Shutdown my server
  3. I Quiesce and break snapmirror
  4. I Put the snapmirrord LUN offline and I change the serial number exactly as it was on source controller
  5. I unmap the old LUN,
  6. I create the same initiator groups.
  7. I put the new LUN online
  8. I map new LUN to the igroup
  9. I Start server
But  any partition was mounted. My logical volume is not available
--- Logical volume ---
  LV Name                /dev/VgB/lvB
  VG Name                VgB
  LV UUID                YW5brO-5lHj-KQ1k-8YKa-ggv3-pidA-um9JEq
  LV Write Access        read/write
  LV Status              NOT available
  LV Size                14.00 GB
  Current LE             3584
  Segments               1
  Allocation             inherit
  Read ahead sectors     auto
For nodename of the controller is alerady used by vmware host, I think that I cannot change it.
Br
SAMIH
GerarCR
If you cannot change the target nodename, I THINK you are going to have to remap the lun again, because the lun is mapped to the other filers iqn.
Regards,
Gerardo
sprajavel
Hi,
 i am new to this forum... how to open a topic.. i need help for fas2020. pls help me...
