General Discussion
Brocade 300 OS and Netapp Ontap Compatibility
KH1979
We have Brocade 300  switch running 7.0 OS.  Would like to know where to find if this version will be supported on a Ontap 9.5 cluster.
Thanks
Kathy
2 REPLIES 2
Ontapforrum
Hi,
This is the recommended page for checking interoperability.
http://support.netapp.com/matrix
I checked it for you: Looks like,
Brocade Switch 300 and ONTAP 9.5, 7.0 FOS firmware is not compatible, however there are versions in 7.x.x and 6.x.x which shows compatible.
Have attached the snapshot & exported excel.
Thanks!
kdean1979
THANK you for this information.  I was struggling thru the IMT tool to find this.
