General Discussion
Create XDP Snapmirror using Powershell?
jimmer2880
I'm attempting to create new snapmirror relationships with the XDP relationship type using powershell via New-NcSnapmirror.  However when I enter "XDP" as the relationship type, I get an error that XDP type is unknown.
DOT version: 9.1P15
Does anyone know the correct type?
1 ACCEPTED SOLUTION
donny_lang
Try "vault" without the quotes as the type  - this will create a version-flexible SnapMirror relationship (when it is paired with a version-flexible SnapMirror policy).
5 REPLIES 5
donny_lang
mbeattie
Hi,
The type for XDP is "vault". You can use "Get-Help New-NcSnapmirror -full" to view the possible options for the -Type parameter :
-Type <String>
Specifies the type of SnapMirror relationship. Possible values: dp, ls, vault, restore, transition_data_protection.
/Matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
jim_ctr_merrell
What volume type should I use?  Previously, I was using "DP" when creating the destination volumes.
-Type <String>
The type of the volume to be created. Possible values:
rw - read-write volume (default setting)
ls - load-sharing volume
dp - data-protection volume
dc - data-cache volume (FlexCache)
donny_lang
The volume type is still "DP".
jim_ctr_merrell
thank you.   That worked.
