General Discussion
VSC 6.2 is not working
rakeshtcs
Dear Team,
Very Good noon,
We have Installed the VSC 6.2.2 in our Windows machine and I am not able to do the configuration. Please find the details given below.
ESXI Host: 6.5
VSC: 6.2.2
Please find the log details given below, I would really appreciate if some one could help us on the same.
2018-07-31 12:47:58,312 [::] WARN - CPM-00305: Persistence file etc\cred does not exist.
2018-07-31 12:47:58,343 [::] INFO - vimService.wsdl found at jar:file:/C:/Windows/Temp/jetty-0.0.0.0-8043-smvi.war-_smvi-any-/webapp/WEB-INF/lib/vim.jar!/vimService.wsdl
2018-07-31 12:47:59,562 [::] DEBUG - Reading mount metadata from .\repository\mounts.xml
2018-07-31 12:47:59,562 [::] DEBUG - Reading backup metadata from .\repository\backups.xml
2018-07-31 12:47:59,562 [::] DEBUG - Reading backupJob metadata from .\repository\scheduledBackups.xml
2018-07-31 12:47:59,562 [::] DEBUG - Reading file restore generated keys from file .\repository\fileRestoreKeys.xml
2018-07-31 12:47:59,562 [::] DEBUG - Reading mount metadata from .\repository\sfrMounts.xml
2018-07-31 12:47:59,562 [::] DEBUG - Reading mount metadata from .\repository\vmdkMounts.xml
2018-07-31 12:48:01,015 [::] WARN - FLOW-13002: Error validating embedded database tables, reloading. Reason: Table/View 'FLOW_CONTEXT' does not exist.
2018-07-31 12:48:02,718 [::] DEBUG - Registering Job Loader Plugin: jobLoader
2018-07-31 12:48:02,734 [::] DEBUG - Loading jobs from: C:\Program Files\NetApp\Virtual Storage Console\smvi\server\.\repository\backup\jobs
2018-07-31 12:48:02,734 [::] DEBUG - Loading file restore job from: C:\Program Files\NetApp\Virtual Storage Console\smvi\server\.\repository\restore\jobs
2018-07-31 12:48:02,828 [::] INFO - SnapManager for Virtual Infrastructure Server 6.2.2 (Build: 180424) is starting
2018-07-31 12:48:02,828 [::] INFO - HSSV API 1.0 (build date='180424_2002', version='5883') is starting
2018-07-31 12:48:03,015 [::] WARN - FLOW-10099: Exception while enabling Java Management Extensions
2018-07-31 12:48:03,874 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:48:03,874 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:48:03,874 [::] DEBUG - Register smviUser is empty
2018-07-31 12:48:03,890 [::] DEBUG - VSphereCredentialVimClientLoader: stored VC credential not validated
2018-07-31 12:48:03,890 [::] DEBUG - Running VimClientFactory Cache Cleaner...
2018-07-31 12:48:03,890 [::] DEBUG - VimClient Cache: 0 removed, 0 remain in cache
2018-07-31 12:48:03,890 [::] DEBUG - Done running VimClientFactory Cache Cleaner...
2018-07-31 12:48:05,781 [::] DEBUG - Processing job file: file:/C:/Program%20Files/NetApp/Virtual%20Storage%20Console/smvi/server/./repository/backup/jobs/retention_job.xml
2018-07-31 12:48:05,906 [::] DEBUG - Processing job file: file:/C:/Program%20Files/NetApp/Virtual%20Storage%20Console/smvi/server/./repository/restore/jobs/fileRestoreUnmount_job.xml
2018-07-31 12:48:06,015 [::] INFO - FileRestoreUnmount Job is kicked off
2018-07-31 12:48:06,015 [::] DEBUG - Instantiating service url 'https://localhost:8043/smvi/services/InternalHvss' for class 'com.netapp.smvi.api.InternalHyperVisorStorageService' using user 'null'
2018-07-31 12:48:13,890 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:48:13,890 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:48:13,890 [::] DEBUG - Register smviUser is empty
2018-07-31 12:48:23,905 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:48:23,905 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:48:23,905 [::] DEBUG - Register smviUser is empty
2018-07-31 12:48:33,920 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:48:33,920 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:48:33,920 [::] DEBUG - Register smviUser is empty
2018-07-31 12:48:43,920 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:48:43,920 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:48:43,920 [::] DEBUG - Register smviUser is empty
2018-07-31 12:48:53,921 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:48:53,921 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:48:53,921 [::] DEBUG - Register smviUser is empty
2018-07-31 12:49:03,926 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:49:03,926 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:49:03,926 [::] DEBUG - Register smviUser is empty
2018-07-31 12:49:13,929 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:49:13,929 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:49:13,929 [::] DEBUG - Register smviUser is empty
2018-07-31 12:49:23,944 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:49:23,944 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:49:23,944 [::] DEBUG - Register smviUser is empty
2018-07-31 12:49:33,948 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:49:33,948 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:49:33,948 [::] DEBUG - Register smviUser is empty
2018-07-31 12:49:43,956 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:49:43,956 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:49:43,956 [::] DEBUG - Register smviUser is empty
2018-07-31 12:49:53,960 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:49:53,960 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:49:53,960 [::] DEBUG - Register smviUser is empty
2018-07-31 12:50:03,962 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:50:03,962 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:50:03,962 [::] DEBUG - Register smviUser is empty
2018-07-31 12:50:13,975 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:50:13,975 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:50:13,975 [::] DEBUG - Register smviUser is empty
2018-07-31 12:50:23,988 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:50:23,988 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:50:23,988 [::] DEBUG - Register smviUser is empty
2018-07-31 12:50:33,999 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:50:33,999 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:50:33,999 [::] DEBUG - Register smviUser is empty
2018-07-31 12:50:44,010 [::] WARN - CPM-00305: Persistence file ../../etc/vsphere-credentials does not exist.
2018-07-31 12:50:44,010 [::] DEBUG - OperationContext is null. Could not find register smviUser.
2018-07-31 12:50:44,010 [::] DEBUG - Register smviUser is empty
2018-07-31 12:50:54,105 [::] WARN - CPM-00305: Persistence file etc\cred does not exist.
2018-07-31 12:50:54,105 [::] DEBUG - Global configuration is not currently set
2018-07-31 12:50:54,511 [::] WARN - CPM-00305: Persistence file etc\cred does not exist.
2018-07-31 12:50:54,511 [::] DEBUG - Global configuration is not currently set
2018-07-31 12:50:54,886 [::] DEBUG - Requesting new client connection for https://[email protected]/****@eurdc01vc004.eu-rdc01.nexperia.com/sdk/vimService
2018-07-31 12:50:59,261 [::] DEBUG - Client acquired for https://[email protected]/****@eurdc01vc004.eu-rdc01.nexperia.com/sdk/vimService
2018-07-31 12:50:59,511 [::] DEBUG - Authenticated user [email protected] against VirtualCenter host eurdc01vc004.eu-rdc01.nexperia.com.
2018-07-31 12:50:59,511 [::] DEBUG - VSphereCredentialVimClientLoader: successfully validated stored VC credential
2018-07-31 12:58:03,902 [::] DEBUG - Running VimClientFactory Cache Cleaner...
2018-07-31 12:58:03,902 [::] DEBUG - VimClient Cache: 0 removed, 1 remain in cache
2018-07-31 12:58:03,902 [::] DEBUG - Done running VimClientFactory Cache Cleaner...
2018-07-31 13:00:00,056 [::] INFO - FileRestoreUnmount Job is kicked off
2018-07-31 13:00:00,071 [::] DEBUG - Instantiating service url 'https://localhost:8043/smvi/services/InternalHvss' for class 'com.netapp.smvi.api.InternalHyperVisorStorageService' using user 'null'
2018-07-31 13:00:00,087 [::] DEBUG - BackupRetentionJob is being kicked off
2018-07-31 13:00:00,087 [::] DEBUG - Log file retention date: 24.07.2018
2018-07-31 13:00:00,259 [::] DEBUG - Calling the Retention service
2018-07-31 13:00:00,352 [applyRetention:ffb906f07cba26984adfc0497b57dfb0:] INFO - Starting backupTimebasedRetention request
2018-07-31 13:00:00,399 [applyRetention:ffb906f07cba26984adfc0497b57dfb0:] INFO - BackupTimebasedRetention is complete.
2018-07-31 13:00:00,399 [applyRetention:ffb906f07cba26984adfc0497b57dfb0:] DEBUG - FLOW-11007: Operation completed
2018-07-31 13:00:00,415 [applyRetention:ffb906f07cba26984adfc0497b57dfb0:] DEBUG - ASUP: No storage system added to SMVI server
I have attached the Server log and SMVI log as well for your views
0 REPLIES 0
