General Discussion
vol offline failing to offline a volume in 7 mode 8.1.4p1
yvgr79in
Unable to offline a volume with below message in Netapp 7 Mode system, volume has no shares, no exports etc.
storage01> vol offline users01
The following prevents offline of volume users01
        dump
vol offline: Volume is in use by other operations. (users01).
3 REPLIES 3
naveens17
when your triggering vol offline command can you check what it is logging in the messages file..?
yvgr79in
no message on messages after the vol offline command only terminal it came up with above stated message. Nothing fishy on messages to offline this vol.
naveens17
can you check :
set advanced or diag
filer*>ndmpd status
filer>backup status
if no NDMP or backup activity then best to do the failover & failback then give a try..(might be a hung process is not allowing to delete it)
