ONTAP Discussions
Cutting over iSCSI and FC LUNs between filers
malvinmunyaradzi
I need to cutover from one FAS2240-2 to FAS2552 using SnapMirror to transfer the data. Using OnTap 8.2.3 7-Mode.
Can someone advise on the right way to migrate iSCSI and FC LUNs between filers?
iSCSI LUNS are on Windows and Linux servers and FC LUNS are on AIX server.
2 REPLIES 2
Anoop
Hi,
Hope this helps:
https://library.netapp.com/ecmdocs/ECMP1635994/html/GUID-97AFCAB0-CEEC-4816-9273-6D7948E6690C.html
https://kb.netapp.com/support/index?id=1011238&page=content&locale=en_US
Regards,
Anoop
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
malvinmunyaradzi
Hello Anoop
Thank you for you help but I am currently coping data across using snapmirror.
What I am relly concerned with is after coping data across, when I boot the new Filer will the servers see the luns without formating them?
Will the servers see the storage as they used to do on the old filer without any issues?
Regards
Malvin
