ONTAP Discussions
Delete (DEL) Key not working if connected with putty
Bitboy85
Hello everyone,
i'm searching for way to use the delete key on the keyboard when i'm conntected through putty.
Every time i hit the key it only outputs ~3 to the console.
For linux there is a way editing /etc/inputrc, is there a way for ontap? I have version 8.1.2P7
Many Thanks
5 REPLIES 5
JGPSHNTAP
works fine for me
Bitboy85
The problem is similar to this description: http://superuser.com/questions/94436/how-to-configure-putty-so-that-home-end-pgup-pgdn-work-properly-in-bash
I've already tried to choose a different terminal-type string and selected different options in the terminal -> keyboard menu.
In default settings, the keys are mapped that way:
del -> [3~
insert -> [2~
pos1 -> [1~
end -> [4~
pgup -> [5~
pgdw -> [6~
other keys like backspace and arrows, even german umlauts (yes keyboard layout is german) works fine.
puppyjohn83
Have you tried clearing your cache in Putty?
aborzenkov
By default PuTTY maps BACKSPACE key to literal DEL (0177).
Bitboy85
Tried a profile reset but it didn't help. I'm wondering why its working for others.
