ONTAP Discussions
Help with ONTap 9.1 routing
pfwhufc
I am testing the waters with ONTap 9.1, and fired up a simulator version.
Aside from the differences in commands, I cannot connect externally to, or from any of the addresses bar 1 - 10.xx.xx.214.
I am thinking that the routing tables seem to be incomplete, and not having had any prior look at this version of ONTap, I am struggling.
Firstly, yes they are in dns, A record, and PTR reverse records in place. nslookup all fine.
Booted up, did the CTRL-C, Option 4.
Supplied the name, IP etc ..., and it did it all for me, and this is what I have: -
natestclus::> network route show
Vserver             Destination           Gateway           Metric
Cluster               0.0.0.0/0                10.xx.xx.254  20
natestclus         0.0.0.0/0                 10.xx.xx.254  20
network interface show
                              Logical                            Status              Network                    Current           Current         Is
Vserver                Interface                          Admin/Oper   Address/Mask          Node               Port               Home
Cluster
                               natestclus-01_clus1    up/up               10.xx.xx.213/24     natestclus-01 e0a               true
                               natestclus-01_clus2    up/up               10.xx.xx.214/24     natestclus-01 e0b               true
natestclus
                               cluster_mgmt                up/up                10.xx.xx.202/24    natestclus-01 e0d               true
                               natestclus-01_mgmt1 up/up                 10.xx.xx.203/24   natestclus-01 e0c                true
natestclus::> network port show
Node:   natestclus-01
        Speed (Mbps)      Health
Port          IPSpace           Broadcast Domain     Link    MTU    Admin/Oper           Status
e0a          Cluster              Cluster                          up       1500    auto/1000              healthy
e0b          Cluster              Cluster                          up       1500    auto/1000              healthy
e0c          Default              Cluster                          up       1500    auto/1000              healthy
e0d          Default              Cluster                          up       1500    auto/1000              healthy
natestclus::> cluster show
Node                       Health     Eligibility
natestclus-01         true           true
natestclus::> system service web show
External Web Services:   true
                              Status:  online
      HTTP Protocol Port:   80
    HTTPS Protocol Port:  443
              HTTP Enabled:   false
natestclus::>security login show
Vserver:   natestclus
        Authentication                          Acct         Is-Nsswitch
User/Group Name     Application                Method              Role Name   Locked   Group
admin                           console                     password          admin            no            no
admin                           http                             password          admin            no            no
admin                           ontapi                        password          admin            no            no
admin                           service-processor   password          admin            no            no
admin                           ssh                            password          admin             no            no
autosupport                console                     password          autosupport  no            no
natestclus::>network route show-lifs
Vserver: Cluster
Destination                     Gateway             Logical Interfaces
0.0.0.0/0                           10.xx.xx.254      natestclus-01_clus1,
        natestclus-01_clus2
Vserver:  natestclus
0.0.0.0/0                           10.xx.xx.254      cluster_mgmt,
        natestclus-01_mgmt1
I can ping 1 of the 4 interfaces - 10.xx.xx.213
I can https to i, but when I try and sign in with username admin (not linked to AD), I get: -
System Manager will not launch other than node and cluster management LIF (Error: 1)
Any help would be greatly appreciated.
Thanks.
3 REPLIES 3
pfwhufc
Just had the simulator reboot itself, and now when I do: -
natestclus
I just have the above.
The other 3 interfaces have gone.
network port show shows all 4, with no Broadcast Domain, and Health Status is blank.
network route show just has natestclus, not Cluster as well.
robinpeter
I dont have the snaswer for your interface disappering.. thats quiet strange. follow the simulator setup guide.
but you should not configure your cluter interconnect network and mgmt network in same subnet.
and by default cluster interconnect network is not  routable, should not have a gateway.
here is some example how its should be looks like for a 4 node cluster.
cluster1::> network interface show
Cluster
            cluster1-01_clus1
                         up/up    169.254.201.217/16 cluster1-01   e0a     true
            cluster1-02_clus1
                         up/up    169.254.137.178/16 cluster1-02   e0a     true
            cluster1-03_clus1
                         up/up    169.254.101.214/16 cluster1-03   e0a     true
            cluster1-04_clus1
                         up/up    169.254.123.170/16 cluster1-04   e0a     true
cluster1
            cluster1-01_mgmt1
                         up/up    192.168.0.111/24   cluster1-01   e0c     true
            cluster1-02_mgmt1
                         up/up    192.168.0.112/24   cluster1-02   e0c     true
            cluster1-03_mgmt1
                         up/up    192.168.0.113/24   cluster1-03   e0c     true
            cluster1-04_mgmt1
                         up/up    192.168.0.114/24   cluster1-04   e0c     true
            cluster_mgmt up/up    192.168.0.101/24   cluster1-01   e0c     true
cluster1::> network route show
cluster1
                    0.0.0.0/0       192.168.0.1     20
As you can see "Cluster" netowrk dont have routing address.
only the mgmt svm "cluster1" have routing.
and you should be doing all the mgmt via cluster_mgt or node_mgmt LIF.
pfwhufc
Thanks. I have now corrected: -
Cluster
                               natestclus-01_clus1    up/up               172.xx.xx.240/16     natestclus-01 e0a               true
                               natestclus-01_clus2    up/up               172.xx.xx.241/16     natestclus-01 e0b               true
natestclus
Node:   natestclus-01
        Speed (Mbps)      Health
But it still doesn't work - still cannot ping, or connect externally.
On the filer itself, I can ping as follows: -
natestclus::> ping 10.xx.xx.202
10.xx.xx.202 is alive
natestclus::> ping 10.xx.xx.203
10.xx.xx.203 is alive
natestclus::> ping 172.xx.xx.240
no answer from 172.xx.xx.240
natestclus::> ping 172.xx.xx.241
no answer from 172.xx.xx.241
I notice that your setup has all the Cluster vserver addresses on just 1 port, and the same on cluster1.
