ONTAP Discussions
Test system NFS access to a snapshot of a production volume
wgkorb
We have a volume that contains data served via NFSv3 to a production system. From time to time, we'd like to use SnapDrive for Unix (SDU) to create a snapshot of that volume and mount the data on a test system. The test system should not have access to the production volume, for obvious reasons.
I have been able to create the snapshot and mount it in a different place on the production server, no problem.
# snapdrive snap create -fs /data/prod -snapname refresh_20171230_0040
Starting snap create /data/prod
  WARNING:  DO NOT CONTROL-C!
            If snap create is interrupted, incomplete snapdrive
         generated data may remain on the filer volume(s)
         which may interfere with other snap operations.
Successfully created snapshot refresh_20171230_0040 on corp-dc-8040-nfs:/vol/vol_data
        snapshot refresh_20171230_0040 contains:
        file system: /data/prod
        filer directory: corp-dc-8040-nfs:/vol/vol_data/data_prod
# snapdrive snap connect \
 -fs /data/prod /data/stgtst \
 -noreserve -clone unrestricted -verbose \
 -snapname corp-dc-8040-nfs:/vol/vol_data:refresh_20171230_0040
 connecting /data/stgtst
          to filer directory: corp-dc-8040-nfs:/vol/vol_data_0/data_prod
        Volume copy corp-dc-8040-nfs:/vol/vol_data_0 ... created
                 (original: vol_data)
Successfully connected to snapshot corp-dc-8040-nfs:/vol/vol_data:step8img_stg_20171230_0040
        file system: /data/stgtst
0001-860 Info: Host interface 172.16.194.56 can see storage system corp-dc-8040-nfs,
but has read-only NFS permission to directory /vol/vol_stepimages/stepimages_prod.
If this is intentional (examples: your routing setup will only use allowed
interfaces; the directories are mounted with the read-only option; etc.), you
may safely ignore this warning.
Otherwise, we suggest verifying NFS permissions on the storage system to avoid any
potential I/O errors.
This last bit appears to be a warning, because when the command completes, the snapshot is mounted on /data/stgtst and I can successfully create, modify, and delete files & directories in that share. So far, so good.
However, when I try to run the same command on the test system, which is not included in the export policy for the production volume, it fails as follows:
        Cleaning up ...
 destroying empty snapdrive-generated flexclone corp-dc-8040-nfs:/vol/vol_data_0 ... done
0001-860 Info: Host interface 172.20.36.30 can see storage system corp-dc-8040-nfs,
but has read-only NFS permission to directory /vol/vol_data/data_prod.
0001-034 Command error: mount failed: mount.nfs: access denied by server while mounting corp-dc-8040-nfs:/vol_data_0/data_prod
So the mount fails due to the test server not being included in the export policy of the production volume.
Is there a way using SDU to complete the mount on the test server by using a different export policy? What is the best practice for this type of operation?
Thanks,
Bill
1 REPLY 1
AlexDawson
Hi there,
I have reviewed the manual for SDU at https://library.netapp.com/ecm/ecm_download_file/ECMLP2565549 and there is a configuration option of "check-export-permission-nfs-clone" (Page 38).
I do not have a facility easily available to test, but have you tried turning this option "off" in the snapdrive.conf file on your system?
