ONTAP Hardware
FAS 2554 and DS4246 shelves
BillyRey
Can someone tell me the max DS4246 shelves that can be connected to a FAS 2554 with duel controllers?
1 ACCEPTED SOLUTION
pedro_rocha
With ONTAP 9.8 you can have 144 drives on the FAS2554.
You can have 5 shelves of that model. Max stack size is 5 for this shelf.
You can always check that on hwu.netapp.com (account required).
Regards,
Pedro.
3 REPLIES 3
pedro_rocha
Regards,
Pedro.
pedro_rocha
And please be aware of this also:
Max Stack Size
- up to 5 expansion shelves in the stack with HDD Drives
 - up to 3 expansion shelves in the stack with SSD Drives
junwang
Hi, BillyRey
In ONTAP9.8 version, FAS2554 can accommodate up to 144 disks in the DS4246 disk cabinet, and can accommodate up to 5 DS4246 disk cages, Max Number of DS4246 Shelves  1 internal + 5 external.
The following image shows the information found on the HWU website.
