Simulator Discussions
VSIM for ONTAP 8.2.4 P6 and ONTAP 8.2.5 P1
johnsokc
Wondering if anyone might be able to point me in the right direction for downloading VSIM for ONTAP of ONTAP 8.2.4 P6 and ONTAP 8.2.5 P1 .  We support those in our environment and wanted to do some testing in a staged environment to see if we could simulate some fixes before we deploy them to the field.
Thanks in advanced.
3 REPLIES 3
Ontapforrum
Hi,
On the Simulator download page, there is only 8.2.3 & 8.3 image available.
https://mysupport.netapp.com/tools/download/ECMLP2538456DT.html?productID=61970&pcfContentID=ECMLP2538456
Please have a look at this thread, it has a similar query and a useful response/workaround:
https://community.netapp.com/t5/Simulator-Discussions/8-2-4-Simulator/td-p/138153
Thanks!
johnsokc
Thank you!
Ontapforrum
Just FYI:
I upgraded by Ontap 9.6 SIMULATOR from 9.6 to 9.6P4 using standard Prod ONTAP Image and it worked. Thanks to Alex in the thread I mentioned. I have been using simulators for sometime now, but had never upgraded the SIMULATOR, infact I wasn't aware if it is possible. It does work.  You should be alright, good luck!
Upgraded my SImulator From 9.6 to 9.6 P4:
ONTAP96::> cluster image show
Node Current Version Installation Date
ONTAP96-01 9.6P4 11/26/2019 21:10:58
ONTAP96-02 9.6P4 11/26/2019 22:07:46
2 entries were displayed.
ONTAP96::*> system node image show
Is Is Install
Node Image Default Current Version Date
ONTAP96-01
image1 false false 9.6 -
image2 true true 9.6P4 11/26/2019 21:10:58
ONTAP96-02
image2 true true 9.6P4 11/26/2019 22:07:46
4 entries were displayed.
