VMware Solutions Discussions
Backup Virtual Machine (vmdk and RDM LUN FC) with Virtual Storage Console 4.0 ?
jarquillo
Hello,
i have four ESX 5i in a cluster. And i have two virtual machine Windows 2008 R2 SP1 cluster failover with this configuration:
I can make backup this virtual machine with Virtual Storage Console 4.0 or is not supported ?
Hard disk 1 - Virtual Disk (vmdk).
Hard disk 2 - Virtual Disk (vmdk).
Hard disk 3 - Mapped RAW LUN
Hard disk 4 - Mapped RAW LUN
Hard disk 5 - Mapped RAW LUN
Hard disk 6 - Mapped RAW LUN
Hard disk 7 - Mapped RAW LUN
Hard disk 8 - Mapped RAW LUN
Hard disk 9 - Mapped RAW LUN
Hard disk 10 - Mapped RAW LUN
Hard disk 11 - Mapped RAW LUN
Hard disk 12 - Mapped RAW LUN
Hard disk 13 - Mapped RAW LUN
Lot of thanks.
Regards.
i can backup a virtual Machine
1 ACCEPTED SOLUTION
GARDINEC_EBRD
Just to be clear; VSC will not snapshot the data held in the RDM's, just the datastores containing the VMDK's only.  Snapshots of the volumes containing the RDM LUN's will need to be done separately via SnapManager/SnapDrive or similar.  Correct?
8 REPLIES 8
radek_kubka
Hi,
What protocol are you using: FC, iSCSI (in guest initiator, ESX stack)?
Any data in these RDMs? Normally you would use Snap Managers for specific application to handle this.
Regards,
Radek
jarquillo
FC.
Lot of thanks.
Regards.
Jorge Arquillo
Specialist Consultant in Storage and Backups
http://www.seidor.es
Tel: +34 93 304 32 22
Fax: +34 93 317 68 18
Pujades, 350 2ª
Edificio Inbisa 22@
08019 Barcelona
España
Antes de imprimir este mensaje, asegúrese de que sea imprescindible. Proteger el medio ambiente está a nuestro alcance.
La información que contiene este correo electrónico es confidencial y compete exclusivamente al destinatario. Si Vd ha recibido esta comunicación por error, por favor, notifíquelo inmediatamente al remitente y borre el mensaje junto con sus ficheros anexos sin leerlo, copiarlo, grabarlo, distribuirlo o divulgarlo o hacer cualquier otro uso de la información sin el consentimiento de la empresa. El correo electrónico vía Internet no permite asegurar la confidencialidad o correcta recepción de los mensajes, por lo que Seidor no asume responsabilidad alguna por los daños causados.
The information contained in this communication is confidential, may be privileged and is intended for the exclusive use of the above named addressee. If you receive this communication in error, please notify the sender immediately and delete it, and all its attached documents. If you are not the intended recipient, you are expressly prohibited from reading, copying, distributing, disseminating or, in any other way, using any of the information without the company consent. Please note that Internet e-mail guarantees neither the confidentiality nor the proper receipt of the message sent, so that Seidor shall not be liable for any damages caused.
De: Radek Kubka
Enviado el: jueves, 31 de mayo de 2012 12:31
Para: Jorge Arquillo
Asunto: - Re: Backup Virtual Machine (vmdk and RDM LUN FC) with Virtual Storage Console 4.0 ?
<https://communities.netapp.com/index.jspa>
created by Radek Kubka<https://communities.netapp.com/people/radek.kubka> in Data ONTAP - View the full discussion<https://communities.netapp.com/message/82896#82896>
Hi,
Regards,
Radek
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/82896#82896>
Start a new discussion in Data ONTAP by email<mailto:discussions-community-products_and_solutions-data_ontap@communities.netapp.com> or at NetApp Community<https://communities.netapp.com/choose-container.jspa?contentType=1&containerType=14&container=2877>
radek_kubka
Providing, you are not using NPIV, you can use VSC backup with VMware snapshot for VSS consistency.
Any application will not be aware of backup taking place though, so you would need to manually truncate logs.
jarquillo
A lot of thanks.
Regards.
Jorge Arquillo
Pujades, 350 2ª
Edificio Inbisa 22@
08019 Barcelona
España
De: Radek Kubka
Enviado el: jueves, 31 de mayo de 2012 12:41
created by Radek Kubka<https://communities.netapp.com/people/radek.kubka> in Data ONTAP - View the full discussion<https://communities.netapp.com/message/82899#82899>
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/82899#82899>
GARDINEC_EBRD
radek_kubka
Well, not exactly.
VSC can trigger VMware snapshot on RDMs (providing they are in virtual mode), so this can give OS & VSS consistency for certain aps.
That said, my preferred (& generally recommended) way is to use VSC just for backing up OS partitions, & then using relevant SnapManagers for backing up of respective application data LUNs.
Message was edited by: Radek Kubka
jarquillo
ok.
Lot of thanks.
Regards.
Jorge Arquillo
Pujades, 350 2ª
Edificio Inbisa 22@
08019 Barcelona
España
jarquillo
OK.
Lot of thanks.
Regards.
Jorge Arquillo
Pujades, 350 2ª
Edificio Inbisa 22@
08019 Barcelona
España
