VMware Solutions Discussions
Problems with VSC 6 with Data Ontap 8.1.4.P7
sanadmin_do
Our VMWare administrators are using the VSC plugin 6. About this plugin they also want to delete LUN's. By some LUN's they get the following error message:
faultCode : Server.Processing
faultString:'java.lang.RuntimeExeption : Current vCenter Server context is unknown'
faultDetail:'null'
In the log of the affected NetApp no error message is present. Does anyone have an idea why the error occur?
1 ACCEPTED SOLUTION
sanadmin_do
Using the NetApp support we were able to solve the problem: VSC completely de-installed, deleted under Program Files, the corresponding folder manually and VSC reinstalled.
When upgrading from VSC 5 after 6 probably an error has occurred, therefore the complete installation.
9 REPLIES 9
wesprather
I'm seeing this on 8.1.4P8, as well.  Still looking...
sanadmin_do
I have a case opened at NetApp. Let's see what NetApp says.
Caludio
Hi!,
Do you have any news? I'm having the same issue with VMWare 6 and DOT 8.1.4P8...
florianmoje
same probleme here, any news?
Caludio
We have the issue in any interaction with VSC.
After a reboot of the vCenter Server (where the VSC was installed), we reconfigure storages in VSC and the problem was solved.
sanadmin_do
@Caludio: Thanks for your information. We will try it.
We are in contact with the NetApp Support. When we have a solution, we will announce it here.
Norm
Do you happen to have an update on this issue?
florianmoje
...any solution? We are still facing this issue 😞
sanadmin_do
