VMware Solutions Discussions
Restoring Larger Virtual Machines
menzies
We have been discussing a challenge that I wanted to throw out to the wider community.  The challenge is what is the best method to restore a large (VMware) virtual machine?
Some context:
  • 7-Mode 8.x environment
  • vSphere 5
  • Virtual machines up or over 1.5TB in size
The customer is using VSC but when restoring the VM it is taking a very long time, consuming a lot of resource on the controller and they have had the restore fail.
Our understanding is that the VSC process is using SFSR so essentially doing a copy which is why it takes so long.  A couple of suggestions that have been put forward:
  • Using Storage VMotion to speed the process.  If anyone has recent references to this and / or experience it would be useful
  • Manually use sisclone to do it
Both methods are outside VSC which is a shame, but if anyone does have practical experience of either approach or another we would be keen to hear.
Many thanks
Craig Menzies
2 REPLIES 2
dburkland
I have ran into similar issues before and have done the following to restore larger VMs:
  • Mount the VSC backup of the VM's datastore
  • Remove the bad copy of the VM from the VMware inventory (You can delete it as it is useless at this point)
  • Browse into the mounted VSC backup datastore and import the VM into the inventory
  • Power on the VM and validate that it is working properly
  • Storage vMotion the VM back to its original datastore
  • Unmount the VSC backup datastore
This process seemed to work well however we were using 10GbE-connected NFS datastores. Hopefully in the future VSC will be able to perform sisclone operations for any restore jobs.
Hope this helps,
Dan
menzies
Dan, thank you for the quick reply.
Good to hear someone as worked through this process.
