VMware Solutions Discussions
SMVI : Running a Post Backup PowerShell Script
richard_heath
Hi,
I need some help and guidence on scripting in SMVI? I have a power shell script that creates a SV snapshot and updates as Snap vault relationship from a consistant snapshot on the primary filer. I want this to run once the SMVI job has completed but I cant get this to work. The powershell script work fine if run independantly and I have checked that this is not a permissions issue. Please can some one point me to some same scripts or setup guides me on how to get this working as currently SMVI just gives a time out error?
Import-Module DataONTAP
Write-Debug "Begin Main Functions"
# Comfirm succesfull backup
write-eventlog -logname Application -source SMVI -EventID "9990" -EntryType Information -message "SMVI Snapvault Update Started"
# Connect to Snapvault secondary
Write-Debug "Connect to Controller"Connect-NaController -Name Secondary
#Update Snapvault Secondaries and transfer from primary Snapshot
Write-Debug "Snapshot Secondary"
Start-NaSnapvaultSecSnapshot -VolumeName SV_Secondary -ScheduleName SV_Nightly
Write-Debug "Snapvault to Secondary"
Start-NaSnapvaultSecTransfer -SecondaryPath /vol/SV_Secondary/Q_SV_Secondary -PrimarySnapshot smvi_PROD_BACKUPS_novmsnap_recent
Thanks in advance...
1 ACCEPTED SOLUTION
amritad
Here’s a sample script
REM CONTROLLER is the SnapVault target NetApp Controller
set CONTROLLER=torfiler3
REM SECPATH is the path to the SnapVault Volume on the target controller including the qtree
set SECPATH=/vol/vmblock1vault/vmblock1
REM SVSCHED is the schedule name for the retention schedule configured on the SnapVault volume
set SVSCHED=smvi_weeklyvault
REM SVVOLUME is the SnapVault target volume not including the qtree
set SVVOLUME=vmblock1vault
REM USER is the limiter user id for the SnapVault transfer
set USER=limited-SV-user
REM PASSWORD is the password for the limited user
set PASSWORD=smv1rocks
REM SNAPNAME is the name of the snapshot to be transfered
set SNAPNAME=smvi__weeklyISCSI1_recent
REM ZAPIPATH is the path to the ONTAP SDK
set ZAPIPATH="E:\Program Files\NetApp\Virtual Storage Console\smvi\server\scripts"
REM LOGPATH Is the path to the log generated by the SMVI script
set LOGPATH="E:\Program Files\NetApp\Virtual Storage Console\smvi\server\log\scripts"
REM LOGFILE is the logfile generate by the SMVI script
set LOGFILE=SnapVaultScript.log
if %BACKUP_PHASE% == POST_BACKUP goto doSnapVault
goto ende
:doSnapVault
echo SCRIPT STARTING FOR SMVI JOB:%BACKUP_NAME%>>%LOGPATH%\%LOGFILE%
echo BEGIN SNAPVAULT UPDATE>>%LOGPATH%\%LOGFILE%
chdir %ZAPIPATH%>>%LOGPATH%\%LOGFILE%
echo BEGIN SNAPVAULT UPDATE FOR %SVVOLUME%>>%LOGPATH%\%LOGFILE%
apitest.exe %CONTROLLER% %USER% %PASSWORD% snapvault-secondary-initiate-incremental-transfer primary-snapshot %SNAPNAME% secondary-path %SECPATH%>>%LOGPATH%\%LOGFILE%
apitest.exe %CONTROLLER% %USER% %PASSWORD% snapvault-secondary-initiate-snapshot-create schedule-name %SVSCHED% volume-name %SVVOLUME%>>%LOGPATH%\%LOGFILE%
echo END SNAPVAULT UPDATE FOR %SVVOLUME%>>%LOGPATH%\%LOGFILE%
echo
3 REPLIES 3
amritad
goto ende
:doSnapVault
echo
raimiansch
Hi Amritad!
You use the line if %BACKUP_PHASE% == POST_BACKUP goto doSnapVault in you script. Means that, that it is also possible to start scripts befor the backup (PRE scripts)?
I cannot find a documentation about the scripts for SMVI (SVC 2.0). Which parameters are possible and so on.
Have you some docu?
Thanks
Rainer
amritad
Hi
You can take a look at the SMVI BPG. Here’s the link to this
http://media.netapp.com/documents/tr-3737.pdf
Also we have a SnapVault integration script that you can take a look at
http://communities.netapp.com/docs/DOC-8720#comment-4130
Regards
Amrita
