VMware Solutions Discussions
VSC 2 Registration Problem
hollandwl
I've downloaded VSC 2 and installed on a 32 bit Windows 2003 system just fine.  However, when I install on a 64 bit Windows 2008 SP 2 system, it is unable to register itself.  I get the page recommending not going to the site because it is using a self-signed certificate.  I tell it to go ahead anyway and then I get ieframe.dll error.  Next I tried disabling IE's Enhanced Security for admins and users and after clicking past the certificate security warning I get a FORBIDDEN error.  I've tried disabling the firewall, but that does not help either.
Ideas?
2 REPLIES 2
hollandwl
  1. Uninstalled VSC 2, completely
  2. Deleted leftover files/folders
  3. Emptied personal and system temp folders
  4. Cleared all IE cookies, history, and cache
  5. Searched registry and deleted all references to NetApp
  6. Rebooted
  7. Reinstalled VSC 2 and everything went perfectly
Apparently there was some little leftover tidbit from either the VSC 1, RCU, or VIBE that was causing a problem.
basvanberkel
did u use a proxy server in IE ? disable and try again.
