VMware Solutions Discussions
Virtual Storage Console - mounting datastores problem on netapp side
dormelchen
hello together,
we have an problem.
If we mount via VSC datastores for restore on ESXi Hosts, we can mount vmdks to other machines, restore etc.
everything fine.
But if we unmount the datastores, we run into an timeout. And after that,we dont see any mounted datastores in Vsphere.
So i thought, its ok - they are unmounted.
BUT - on netapp side - via oncommand - i see a lot of mounted datastores...
How can i remove these datastores from VSC, which are not used anymore ?
Thank you
1 REPLY 1
georgevj
Do you see any errors in log files? Any clue that may lead to the reason for timeout?
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
