Ask The Experts
FC port conversion to CNA not showing up online
NAYABSK
Hi All,
I have converted a qlogic cna 8324 (8362)  from FC to CNA but i see the port status showing ofline.
May i know what is the configuration needs to be done on the switch side ? To support the CNA type.
Ontap :- 8.2.57Mode
FAS8040
Thanks in advance.
1 ACCEPTED SOLUTION
paul_stejskal
Yes you need to use an approved SFP. If that's not a 10Gb SFP it won't work.
11 REPLIES 11
mjdalton1
I think you want
ifconfig e0g  up
ifconfig e0h up
May want to confirm SFP is 10GbE as well.
Pat_Parent
Have you rebooted ?,   the change is in effect after rebooting the node.
Pat_Parent
confirm that you have the good SFP+, there is a difference between FC and ETH...
NAYABSK
Rebooted already and the port type changed from FC to CNA.
NAYABSK
SFP on the Netapp side showing it supports 4,8 and 16GB speeds (Last screenshot in my post) . Whereas my switch side is a 10Gb SFP If this is the case i cannot use it because the switch end SFP is 10G ?
Pat_Parent
Hello NAYABSK,
When you use a CNA, you are working with Ethernet speed (10GBPS). The speed on the SFP of 4-8-16 GBPS is FC speed. So my guess is that you have the wrong sfp in there.... Do you want to do FCoE with your Setup ?
NAYABSK
Yes, I Want a FCOE.
paul_stejskal
mjdalton1
These are the SFP+ you want.
X6589-R6
332-00279R6,
AFBR-703SDZ-NA1,
AFBR-703SMZ-NA1,
AFBR-703SMZ-NA2,
AFBR-709SMZ-NA1,
AFBR-709SMZ-NA2,
FTLX8571D3BCL-(NQ),
FTLX8574D3BCL-N1
SFP+
LC
XCVR,SFP+,Opt,10GbE,Shortwave
ETH: 10/40 Gbps
5.5, 7.3.5, 8.0.1, 8.1, 8.2RC1, 8.3RC1, 9, 9.0RC1, 9.1RC1, 9.2RC1, 9.3RC1, 9.4RC1, 9.5RC1, 9.6RC1, 11.3
Pat_Parent
So you need the ethernet SFP+ (10 Gbps) because fcoe is encapsulating the fc frames inside ethernet frames.  Be sure to adjust the MTU .,..
Pat_Parent
Sorry for the delay, were you able to get the fcoe going ?
