General Discussion
disable shutdown because of nvram batteries low
adminqskills
Hi everybody,
is it possible to disable the shutdown of the system (FAS2240 CDOT) ? We are running trainings with netapp, therefore it isnt that big problem
running without nvram:
if the NVRAM batteries are dangerously low, the system shuts down automatically every 24 hours to encourage you to replace them. If you reboot the system it will run for another 24 hours before shutting down.
1 ACCEPTED SOLUTION
Ontapforrum
Following option will delay the automatic shutdown.
::> options ra*
raid.timeout 24
The value is in hours; the default is 24, the minimum acceptable value is 0 and the largest acceptable value is 4,294,967,295.
I think 0 will disbale this shutdown. Incase it does not accept 0, then simply set it higher value so that you can continue with your training duration without thinking about it.
1 REPLY 1
Ontapforrum
::> options ra*
raid.timeout 24
