ONTAP Discussions
OSSV Exclude System Volume information
psvw
Hello,
I'm fairly new to Netapp. I have a win2012server in a remote office I am backing up with OSSV. It is currently backing up Dedup .ccc files from D:\System Volume Information\dedup\chunkstore. I wish to exclude this directory as it makes no sense to backup. I have opened up the file-exclude text file from: C:\Program Files\netapp\snapvault\etc. I have added: D:\System Volume Information\ to the exlcude list. Is there anything else I need to perform other then restarting the service for this change to take affect?
Regards,
2 REPLIES 2
Sahana
Hi,
DATA EXCLUSIONS
OSSV can exclude certain data from backup. The following files on the OSSV host can be populated to exclude specific data:
\etc\file-exclude.txt
\etc\path-exclude.txt
\etc\file-system-exclude.txt
The file-exclude.txt and path-exclude.txt files accept wildcards. The file-system-exclude.txt file does not.
Note: The file-system-exclude.txt file is not available on Windows or AIX hosts.
Refer http://www.netapp.com/us/media/tr-3466.pdf page 9
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
raj_shrivastava11
Hi,
If you wish to exclude entire directly, u should add a entry in Pathexluce.txt file instead of Fileexclude.txt.
Fileexclude.txt is for specific file exclusions.
Hope this helps
BR
Raj
