ONTAP Discussions
Problem configuring network interface
COG
Hi All,
Please can someone help with this? In one command e0d and e0f are down and in another they are up. Evidently they are down even after issueing the command - net port modify -node xxxxx -port e0d -up-admin. I need to get the ports up.
xxxxx::*> net port ifgrp show -node xxxx -ifgrp a0a
(network port ifgrp show)
                 Node: xxxx
Interface Group Name: a0a
Distribution Function: ip
       Create Policy: multimode_lacp
         MAC Address: yyyyyyyyyyyyyyyyyyy
   Port Participation: none
       Network Ports: e0d, e0f
             Up Ports: -
           Down Ports: e0d, e0f
xxxxx::*> net port show -node xxxx
(network port show)
Node: xxxx
        Ignore
                                                 Speed(Mbps) Health   Health
Port     IPspace     Broadcast Domain Link MTU Admin/Oper Status   Status
a0a       Default     -               down 1500 auto/-     -       false
a0a-211   Default     136.171.211.0/24 down 1500 auto/-     -       false
e0M       Default     136.171.211.0/24 up   1500 auto/100   healthy false
e0a       Default     -               down 1500 auto/10   -       false
e0b       Default     -               down 1500 auto/10   -       false
e0c       Cluster     Cluster         up   9000 auto/10000 healthy false
e0d       Default     -               up   1500 auto/10000 healthy false
e0e       Cluster     Cluster         up   9000 auto/10000 healthy false
e0f       Default     -               up   1500 auto/10000 healthy false
e7a       Default     -               down 1500 auto/10   -       false
e7b       Default     -               down 1500 auto/10   -       false
1 ACCEPTED SOLUTION
dbenadib
Missing LACP config on switch side ... configure it and a0a will be up
3 REPLIES 3
dbenadib
COG
Thanks! That worked.
Bouba
hello
this issue is a switch isue??
