VMware Solutions Discussions
Problem with luns/volumes
EMPOWERISM
I created volumes/luns in Netapp E2600 and connectes the Netapp to a host with a SAS cable,
The problem is when I create volumes in Netapp I can not see them in the ESX server without rebooting the server or remove the cable and connect it again!
I realy need your help ,Any solutions??????
6 REPLIES 6
radek_kubka
Okay, did you rescan the HBA on the ESX host?
Normally this is the operation used for discovering new LUNs presented to a host.
EMPOWERISM
Yes I rescaned it but there is nothing after rescan ,only I can see them after rebooting or remove the cables?!!!!!
Just for some information ,I am using esx 5.5 and LSI HBA .
rwelshman
Which version of ESX are you running? How many hosts are connected? Do you have a LUN with ID 0 in the list?
EMPOWERISM
I am using esx 5.5 and I connect 3 hosts to it but when it was only 1 host at the begining it was like now.
Yes ,I have a LUN with ID0.
rwelshman
What happens when you perform a rescan on the HBA - does it complete successfully? When you look in the storage adapters section on the ESX hosts, the number of visible LUNs doesn't change?
EMPOWERISM
Yes ,exactly.when I rescan, it completes successfully but no change in the Luns, only when I remove the cable and connect it again or reboot the host , I can see LUNs there.
