VMware Solutions Discussions
Strange behavior increasing space on VMware NFS volume
magritti
Hello everybody
I am increasing the size of an nfs volume used with vmware datastore but when I increase it, the free space in the datastore does not increase, but the used space. Space Reserved for Snapshot Copies is set to 0% and Available Snapshot Reserve Size is 0B.
Can anyone give me an idea of what's going on and how I can fix this?
Thanks and regards
1 ACCEPTED SOLUTION
Sanaman
I would check the free space in the aggregate and check if the volumes in the aggregate are thin or thick provisioned. Also will check same (thin/thick) in VMware side.
1 REPLY 1
Sanaman
