VMware Solutions Discussions
VSC 4.2.1 will not re-scan a vm
dmandell
I've got something I have not run into before, hopefully others have.
I am using VSC 4.2.1 to scan the VMs in my datastores for alignment offsets
I run a scan, so far so good.
I find a Windows 2003 VM that is out of alignment.
I scan it with Uberalign to see that it concurs. (it does)
I use UberALign to align it.
I re-scan with UberAlign and it says it is now in alignment.
I fire up the VM, all looking good
So I go back to VSC and select to scan the datastore again.
VSC scans all of the other VMs in the datastore, but will not re-scan the VM I just aligned.
(or course, it still shows as out of alignment from the initial scan)
I know it does not scan the VM because it never creates a snapshot during the process for this VM.
Any ideas on what is the best plan for resolution?
An I missing something?
Thanks!
Dana
0 REPLIES 0
